Technical Top radiator elbow keeps blowing off
Sillystu84
Birmingham
So back here with another problem after sorting out and replacing ( turbo, dpf, lpegr, hpegr ) and some other bits had the van running fine for about a wk now my issue is I can’t get the coolant right, heating fine m, temp fine, new thermostat fitted but it keeps blowing my top hose the one with the stupid clip in it, I’ve replaced the elbow with new one and again today it’s blow the top elbow off,
What is causing this to happen ?
Also is there a bleed screw anywhere as I can’t find one ?
Model
Ducato 150 multijet
2019
A photo of the type of clip / fitting may help.
I had problems with 2010 1.6 Doblo with the plastic elbow with a rubber inner seal and the wire clip arrangement.
In the end I made new O ring and lubed it up with silicon grease , then was able to firmly push elbow into place locking the clip arrangement securely.
I then pressure tested to be sure.
Fiat have used various types and it forces you to use their expensive hose arrangements.
I started making my own O rings from a Loctite kit after Fiat charged me £37 odd for two O rings, which came in a Fiat sealed bag marked PRC (Peoples Republic Of China)!!!:(
Good morning thanks for reply it’s driving me crazy now this is lol I’m thinking of getting another hose to go straight to rad and use a jubilee clip lol
Good morning thanks for reply it’s driving me crazy now this is lol I’m thinking of getting another hose to go straight to rad and use a jubilee clip lol View attachment 453861
Providing the plastic groove in the radiator is not damaged, try and see if the clip secures the elbow with the rubber sealing ring out temporary so you know it has pushed all the way on.
You can usually see by the way the wire parts of the clip sit in their grooves if that is the problem.
Afterwards try refitting the elbow with it's O ring and well lubricated ideally with silicon grease, if it will push on all the way and you can see the clip lock in, if so and you can't wriggle it off then refit the hose and jubilee clip and test as before. I agree they are a stupid idea, probably done to keep cost down and quick assembly in the factory when brand new!
so after spending nearly 3k on sorting this van out with the lpegr issue ( new turbo, new dpf, new lpegr and hpegr) I’ve found reason as to why the hose keeps blowing off, did a block test this morning and is showing as a blown head gasket not a happy man this morning
Sorry to hear that.
Modern vehicles are over complicated in trying to meet ever more stringent regulations, that no repair is cheap it seems.:(
The pressure relief valve in the rad cap should blow before any part of cooling system fails.
We changed that twice one of another van we had and one brand new and still happened, Did block test this morning which has confirmed ( head gasket or cracked block/head ) within 20secs it went from blue to green
I agree , although many years ago I had a VW Golf (1.5 Auto I think from memory) that had been standing and the rad cap didn't relieve the pressure and blew the end off the plastic radiator much to my surprise.:(
Strangely enough I did manage to recrimp that one using a pair of sash cramps so was lucky and did replace the rad cap.
It was a bit of mismatch car that started off as with a damaged 1500 cylinder head and I got a 1.6 GTI head from a burnt out engine, had some blanks fitted and drilled to match oil ways in the block, fitted blanks in the injector holes using 10p pieces and then used the original carb and manifold, after all that it was quite reliable for a shoe string budget!;)
Hopefully if it is that bad, when stripped down it should be fairly obvious which cylinder.
When only slight I tend to do a "Leak Test" using compressed air, it takes a long time but pin points the faulty cylinder.
Oh no.
That has answered question I was thinking of asking.... how quickly did the block test show result... 20seconds is quick.
Nothing anyone can truly say to ease the pain of that. It's now become an engine rebuild job, thousands of pounds.
Might look into a rebuilt one with a warranty.
That soudns expensive for a head gasket, if that is the problem. Takes me back 60 years ago when I bought my first vehicle 2.25 litre diesel Land Rover. In those days it was fashion? to take the head off a pre-used vehivle to inspect valves, gasket, and look for wear ridges in the cylinders. I duly did this in my parent's driveway, but in those days you could see the cylinder head on opening the bonnet.
I do remmber that a possible weakness in the three main bearing engine, was the shorter distance between cylinders 1/2 & 3/4.
Sorry for late reply been flat out with work but the truck is all back up and running with no issues ,, had to get head skimmed a little and also got it pressure tested, I’ll add some pics you can see where the water was leaking into cylinder
Good job:)
It is nice to have a definite fault when you remove the head, some times it is such a slow leak that only something like the leak test I mentioned will accurately show which cylinder the fault is.
Good job:)
I had a feeling it wasn’t going to be nice tho as is was the back pressure that was popping the hose of rad which is so weird same hose back on and stayed on lol
My top rad hose has just blown off. Have put it back on but its still passing coolant. Should there be a rubber O ring that fits on the rad before the elbow with the metal clip goes over that to fit in the groove? Any part numbers for this o ring?
There are several different designs of that fitting, but generally the rubber sealing ring is in the plastic fitting on the hose.
The sealing area is between the O ring and the straight part of the plastic tube on the radiator, the clip shouldn't blow off if it is correctly in it's groove and not damaged.
Assuming it was only the O ring causing the problem, Fiat will sell you an expensive new hose with fitting, O ring and clip.
I needed several of the sealing O rings on a Fiat Doblo after oil had got in from a leaking oil cooler and damaged the O rings and it was cheaper for me to buy an O ring making kit from Loctite which I was sceptical to use at first , but when measured and done correctly has lasted several years.
If radiator is in good order, you could try and get a pattern hose if possible.
Look carefully atvtge rad. Are the tangs tge clip connects with preset and in good condition. doctgey natch the spring clio right. I cutvtgechise clip off the elbow, fitted tge elbow, tgen fitted tge hose back with a new jubilee clip. Its easier to be certain the elbow is on right with no hose interfering with it. A pain mucking about with a new fitting.
Look carefully atvtge rad. Are the tangs tge clip connects with preset and in good condition. doctgey natch the spring clio 17648501970156416386715493244047.jpgright. I cutvtgechise clip off the elbow, fitted tge elbow, tgen fitted tge hose back with a new jubilee clip. Its easier to be certain the elbow is on right with no hose interfering with it. A pain mucking about with a new fitting.
edit. I reused the old hose from mine and still have the new one. I will NEVER undo another quick release elbow, U treat tgem as partvof the rad now!
Sorry about the Panda Nut socks. All my socks have Pandas on them....
