So Mr Fiat GURUS, please help me with this strange one:
I bought a Stilo 1.6 in February with problems. It was producing rude misfiring, with lack of power and engine rattlong like hell, exhaust's flexi part was worn out, car sounded like crap. Misfiring was constant, engine light ON, beeping all the time, but there were strange conditions (driving for a while, then turning off engine, then 1-2 hour later back on), when in several RPM ranges (2750-3750) there were almost zero misfiring, car did run like a mad horse!
Later I finally was able to read out codes via MES:
Misfire general
Cylinder 1 misfire
Cylinder 1 injection
Below cat
I started to work on the car: D3 connector sorted via fiatforum.com guide, ECU opened, changed a burnt out capacitor, resoldered all pins, and finally I relocated the ECU to the side of the battery tray. Garage fixed flexi exhaust part.
Still misfiring, no change.
I bought two used, but working coils, 4 new NGK plugs; result: tiny bit of less misfiring first, later same, or even worse.
Then miracle happened:
I was in stop'n'go traffic on the autobahn (1000+km in a day), and after a rough letting off - car idling, then I released clutch carelessly, rpm went below 400 or so, car jumped, and almost stopped, but didn't stall, rolled forward - the misfiring just GONE!
Wtf, I was more than happy, and moral of the story:
- car did run perfect for 3 months or so.
Then tiny problems only, once in 2 weeks a below cat Lamdasonde problem, but nothing special.
So at the end of may I finally went to garage again, changed timing belt, pulleys, water pump, all other belts, oil + all filters (+front discs, pads, but that doesn't matter now), car still running fine! Tiny bit of engine shaking while idling and acceleration from low rpm is noticeable, but I guess engine + gearbox mounts are worn out... But all in all, car worked good.
There were 2 occasions when I was working on the car (changing rear wiper motor and things like that) and on these occasions I falted my battery... No problem, charged for a while, then car started no problem. But after these events two things started to get "ordinary": while starting engine low fuel light and or high coolant temperature error fpr 2.5 seconds, then dissappears forever... Car still did run OK.
Although today strange thing happened: started (cold) car, immediately put into 1st, rolling (low speed), idle bit rough like nowadays (I guess because below cat dying o2 sensor), but this time huge rpm drop (to like 300 or so) car almost stops, but goes further, but... MISFIRING REAPPEARS!
Now MES says:
Misfire general
Cylinder 4 misfire
Below cat
I deleted error codes in MES, changed coil at cylinder 4, checked sparkplug (looks OK), wiggled every related connector, and... I didn't dare to start the car. Tomorrow I will find out what's what.
My question after this long @ss behind story:
-Is that possible that both low rpm dropping + almost stalling times I had my timing belt skipping a few teeths? What other stuff can "fix" and also ruin ignition related things in a way like that? Is there even chance skipping teeths if the timing belt and everything - change was less than 2000 km ago. Probably biggest problem is that engine's timings system couldn't be locked properly? Or...
What should I check next? What to do now?
Thank you for your kind words in advance!
Misfire general
Cylinder 1 misfire
Below cat
Now MES says:
Misfire general
Cylinder 4 misfire
Below cat
