One set with cylinder 1 at top dead centre (bottom photo)Thank you Txuchin
Happily mine looks easier, earlier version (shall we call it EVO 1? I want to call it EVO 1)
But good to see rocker cover stays in place, and timing marks applied.
OK, feeling confident about it now
Jock's guide warned me one of those engine mount bolts in the block is tricky for access.
Interestingly different timing marks used for the crank in those two videos (500 on left, Panda right), although both show VVT 1.2
View attachment 470376View attachment 470377
Will be fascinating to see what timing marks I find on mine
The other is with all the pistons half way down (top photo)
Fiat changed the process when the compression was lifted as it's now an just about an interference engine
Makes no difference when using the tipex mark
I'd be tempted to go with TDC (bottom photo) or use the gearbox inspection home, regardless of the timing marks, as there's no spin back on the camshaft, I believe
If using the half way (top photo) there is definitely a bit of spin back from the valve springs, there certainly is on the evo 2 anyhow
I only use the half way only because I have the locking tools but only use it on the crankshaft if doing just the belt
