Has anyone fitted a 1.4 8v punto engine into a panda 169 4x4 2006.
1.4 has variable cam timing is this worth trying to keep working.
Mine is the 1.2 8v so I'm thinking do I need the variation solenoid working on the 1.4 8v?If your panda is a 1.2 8v then the swap will be easier, but, if your panda is a 16v, then it's going to be easier to fit a 1.4 16v, plus, it's the better engine anyway if performance is what you are after.
I just want to add, I have never done or tried the swap, my experience lies in Centos and Puntos where I have done engine swaps.
I'm sure the blocks are the same, just taller or bigger bore size. So oil and water should line up 1.2 valves might be smaller so I would think it would be OK. Only way is to take off and look and measure.Nope will not work, 2mm difference in bore size, I see problems with head gasket valve pockets
Having said that it's not something I have tried personally, so can't be 100%
If you had both you could see if the oil and water galleries line up
The car is far from scrap as its probably one of the cars in the country after restoration last year. Nothing wrong with the engine it's got as such. I'm looking to just upgrade it bit another 20 hp would make a big difference.You can buy a whole 1.2L replacement engine second hand off ebay for ~£150 if you really want to rescue this car.
Nothing is viable on such an old low value car. Its just scrap, sorry to say.
I have both the 1.2L that you have - and the 1.4L that you want to upgrade to. There's 12 HP in it, I really don't know why you'd bother there's so little in it.The car is far from scrap as its probably one of the cars in the country after restoration last year. Nothing wrong with the engine it's got as such. I'm looking to just upgrade it bit another 20 hp would make a big difference.
The 1.4 8v is supposed to be 78hp and the 1.2 is 59hp plus a bit porting on the head should help, in a light car is noticeable amount.I have both the 1.2L that you have - and the 1.4L that you want to upgrade to. There's 12 HP in it, I really don't know why you'd bother there's so little in it.
I can notice it, but 78HP is still real slow. 14 seconds for 0-60 when new! If you want a car with performance then the panda isn't it.The 1.4 8v is supposed to be 78hp and the 1.2 is 59hp plus a bit porting on the head should help, in a light car is noticeable amount.
Thanks for the photos, I'll look closely at them.Not sure where we are going with this
Punto 1.4 8V. 2005 onwards
My 1.2 2010
Piston pockets stand out
Block looks similar has some extra holes mine has the head gasket covering parts over
Thanks yes I spent a lot time sorting out everything. I'm no too bothered about the engine it anything goes wrong as there are plenty of engines around, it has improved since I started driving it. I don't think it was looked after too much before I got it. I enjoy driving it with the few mods I've done, it's much better.I think I saw pictures of the car itself elsewhere on this website (although I could be wrong about that). It looks great and a lot of effort has gone into it. If this is a pride and joy car then I wouldn't advise modding it without the OP being aware the engine lifespan will be reduced. Personally i'd hate to mod my favourite car and 18 months later it blows up....
