Hello, I am planning to replace the timing belt. I have a few questions. My car is a 2009 Fiat Panda. The engine number is 5073034. Based on the engine and cylinder head numbers, it appears to be the Evo2 version.
I plan to use locking tools to secure the crankshaft and camshaft. In this engine version, the notch for the key on the camshaft is likely much larger than the key on the camshaft pulley. Therefore, my plan is as follows: install the locking tools, loosen the tensioner, and remove the belt. Then, while holding the camshaft pulley, loosen it and rotate it fully to the right, with the locking tools still in place. I will then install the belt and tighten it to the maximum. After that, I will rotate the crankshaft twice, set the tensioner, and tighten the camshaft pulley bolt.
I started this thread because I saw in other discussions that loosening the camshaft pulley bolt is considered a mistake. I read posts suggesting that it’s better not to lock the camshaft (if you're sure the current timing is set correctly). Only the crankshaft should be locked. Mark the crankshaft pulley and camshaft pulley. Remove the belt and install the new one. Then tension the belt, and the camshaft pulley should move to the left. So, I loosen the tensioner, move the camshaft pulley to the right (back to the mark), and then tension it again. Best regards.
- Model
- Fiat Panda 1.1 187A1000
- Year
- 2009
