burrowsdeano
- Joined
- Sep 5, 2012
- Messages
- 214
- Points
- 109
Ps there is no filter in the system
Dear Sirs. I have bought new Fiat cars since the 1980s, mainly for quality and design.
Look around the back of the unit for a black plastic cover with magneti marelli written on it. it's held in with three torx 20 screws (if I remember correctly).
Remove those screws, And peer inside the unit. It should be nice and dry, no oil or dirt and definitely no water.
Here, check this thread out : https://www.fiatforum.com/500/425006-one-only-dualogic-failure-thread-21.htmlHi,
I'm hoping someone on here can help me out. My mums fiat 500 suddenly stopped working in terms of getting into gear. It comes up with a transmission error. So we narrowed it down to a leak under the car. So, what I need to know is where is the selespeed fluid tank for me to refill the tank to spot the leak and fix that. I really hope someone can help me asap to get my mum back on the road.
Thank you so much!
No use exactly the same oil to avoid any problems. It's a very specific oil as its not only the specification, but the additive Fiat uses.jrkitching ahmett thank you very much for your help.
I am going to check the fuses and jack the car up this weekend to find the leak and see if there is an oil shortage.
I see throughout the thread, we should be using tutela cs speed oil for the replacement. However, its a bit difficult sourcing this in time for the weekend. Do you know any other compatible oils which are also good?
Thanks,
Minesh
Had a scary moment when arriving at a roundabout slowed to walking pace, no traffic so accelerated a few feet then gearbox went into neutral, revs rose and no drive! stranded in middle of road. switched off and restarted, still no drive! paddles flicked and gear lever moved through all settings and nothing but the annoying "ping ping ping" .
pushed the car to safety and after five minutes of restarting engine and trying to select gear finally had drive again.
have been quoted £450 to repair.
Sorry to hear of your difficulties.
Ouch!
I guess you basically have three choices:
1. You pay to have it repaired. The warranty on the repair should cover you for the rest of the pcp. Definitely the recommended option if you plan on keeping it at the end of the agreement; dualogic problems rarely just go away.
2. You do nothing and hope the problem doesn't recur. If it comes back again, it'll likely keep recurring until it's fixed.
3. You contact Fiat CS and try to get them to make a contribution to the cost of the repair. I'd say your changes of getting at least something are about average; I doubt very much they'd pay all of it.
How much longer have you got on the pcp, and what are you planning to do at the end of it? If you are planning on keeping it, you might want to read the rest of this thread.
Do plan to keep car as like the twinair engine and the paddle gearbox, so will be option 1 and then contact Fiat customer service for some kind of contribution as goodwill, fingers crossed.
OK do you suggest email or phone call?Personally I'd do that in reverse order; if you contact Fiat CS after you've authorised the repair, they might not be so generous.
