Hi. What radios can you provide the code for?
What radio do you have?
It's a VDO in a 57 reg Multipla
I need a code please
Visteon
Portugal
Fiat OC
735484418
Visteon PArt NO: VP7FCF-18C939-AC
SERIAL NO: M003894
07.05.2008
I put a lot of times the wrong code, so now it's just showing "Radio Blocked / Wait". I already have the correct code, but I do not know how to show the blanks to put it. I took off the battery and reconnect again, but it does not work.
What can I do to put the code?
Thanks!
The radio and ignition needs to be switched on continuously until the display shows "- - - - ". Depending on how many wrong codes have been tried, the waiting time could be up to 24 hours.
Hi all. I need radio code for a 2004 for punto.
Serial numbers are as follows
BP237536860185
764237531
Any help would be great
Thanks. S
My car is turned off for more than 24 hours, but the blanks to put the code don't show up.
Hi Davren
Many thanks for the info and code. All went well except somewhere in the process we made a mistake on the numbers I passed on so the code did not work, sorry.
The correct numbers are
815BP535866512636
7 645 358 316
I am sorry, would you re-calculate the code please?
Regards
Bijan
No.... To get the code, I need the numbers from the back of the radio. Once you've posted the numbers, I'll let you know if I can get the code.
Perhaps starting the car used enough power from the battery, to leave insufficient power for the radio momentarily. That could trigger the code request.
Thanks for your reply, Not sure what numbers you need because there are quite a few, so have posted them all exactly how they are written
Hope you can help
BP-Nr. 7 648 292 316
Fiat-Nr 735 499 710 0
815 BP829290771981
Hi Davren,
I am looking for a code for a Blaupunkt CD Changer. The serial is
IDC AO9 and the number is 7 607 769 150. I was wondering if could help?
Many Thanks
Hi Davren,
Thanks for the reply.
BP915024330699.
I will make a donation just now.
Thanks its much appreciated.
Luke
