The one and only code for fiat radio thread.
Good morning everyone,
I'm an happy owner of a FIAT Grande Punto.
Unlikely I have a problem with the radio code. I lost it :(
Radio information are:
GRUNDIG
F199 CD
9.18453-8751
GHT1400
FA646170159993
Thank you very much.
Regards
Ivan
Hi, please could someone help me with the code for my 02 punto ,i just had a new radio for it and need a code please
Bp nbr 7649372316
Prod Nbr 735272569
BP937213820228
Many thanks
Bp nbr 7649372316
Prod Nbr 735272569
BP937213820228
Many thanks
I have the code for your radio.
Click the link below while logged on to the forum.
https://www.fiatforum.com/donations.php
Do not use the anonymous option to donate.
Sorry... I don't have codes for Grundig radios.
Thank you very much for your reply Davren.
It is going to become a kind of nightmare for me.
Can I ask you suggestion on how to get this code?
Do you know any website able to get this code for me, even if it is not for free.
Thank you in advance.
Regards.
Regards.
Based on what Davren's said to other members, most have to be decoded at a radio workshop. I believe they have to physically access the EEPROM.
This is the third code you've asked for in 4 months. Are you a trader?
Hi Davren, i am not a trader. The first one I tried, it was just in case it is the same as on my car pass. And it was the same. The second one was for my new radio which is without any car pass. And because I am still selling the old radio, somebody call me if I am able to find his code. He was replacing the light bulbs in the panel below.
If you want, I will redirect him to this forum to register and donate :).
Hello to everyone,
I'm owner of a FIAT Punto II (year of production 2002) and I have a problem with the radio code because I lost it.
Serial number on radio is :
BP 937227249588
Thank you very much in advance.
Best Regards from Bosnia!
Aleksandar
Hello to everyone,
BP 937227249588
Aleksandar
We are a charity for disabled people. We have a minibus and we are the second owner. The radio code does not work and it's now locked so we have to wait for hours till we can try another code. These are the numbers on the rario
815BP535866512363
BP535866512363
7645358316
Two questions please;
1 - Can anyone help with the code please?
2 - Since we do not drive long enough to be able to try another code, does anyone know how to bypass the WAIT option or if we pull it out and plug it externally to a battery which connections we should wire so the radio stays on long enough.
Many thanks
Bijan
815BP535866512363
BP535866512363
7645358316
Your code is: 1422
The "WAIT" message is a security measure, so can't be bypassed.
To comply with the waiting time with the radio out of the vehicle, connect the negative terminal of a 12 volt battery to pin 8 of connector A (shown in the diagram below), and the positive battery terminal to pins 4 and 7 of connector A. Be careful not to short any of the 8 pins together, then switch the radio on. Depending on how many times a wrong code has been tried, you may need to leave it connected for up to 24 hours.
When the display shows " - - - - " enter the code by pressing preset buttons 1, then 4, then 2, then 2. After refitting the radio in the vehicle, you will need to enter the code again, but there should be no waiting time, or possibly a maximum of 2 minutes.
Good night I lost the code of the radio my fiat 500 when changing the battery can help me on the same attached a photo of the radio thank you very much.
