The one and only code for fiat radio thread.
Thanks, i could install the 9.8 version even if i have limited access to functions on the CN+? The only thing i can do atm is insert and eject cds as the master code request does not let me "navigate"
Yes... if the master code request message you get is the same as in the picture below, you can still do the update. I did one for someone yesterday.
The update instructions say a few times, "clear any error messages using the "ESCAPE" button". Ignore that for the master code request error message, but procede exactly as described with the rest of the instructions.
Thank you!! your the man!! Ill give it a try later on this afternoon!! But first i got to dismantle my CN+ as i inserted the setup disk last night and now it does not eject!! Any thoughts on why this has happend :/
Its one thing after the other!!
Hi Dave, Please could you help me, i have a scudo, 03 plate, i took the battery off and the radio is now blocked on connection, it says i need a code... i found a sticker on the side and there is a serial number of C70000002226K... is there a code to unblock or do i need to buy a new radio..:-( Thank you in advance..
Hi, Welcome to the FF.
Please post all the numbers from the radio including the PU-XXXXX(X) and the other two numbers beginning with C. Then I may be able to get your code.
hi. i just bought an 04 fait punto active sport. had to change the battery and now its asking for a code which wasnt given with the car. would you be able to help?
codes on the side are:
: bp237547043609
: 7 642 375 316
: product number 735 337 934
many thanks
: bp237547043609
: 7 642 375 316
many thanks
I can get the code for your radio.
https://www.fiatforum.com/donations.php
: bp237547043609
: 7 642 375 316
many thanks
Thanks for donating to the forum. (y)
Your code is: 4222
Davren,
The numbers on the radio are as follows.
815BP037330251243
7 640 373 316
021614
735 324 397 0
tHANKS,
mATT
Hi I had to disconnect the battery the other day and didnt think, that the radio wouldnt work afterwards:eek:. As I did never receive a code for that radio (second hand car), i hope I will find some help here.
Its a fiat punto from 2002 with a Blaupunkt radio.
BP937215695315
Prod. Nr. 735 289 639
BP-Nr. 7 649 372 316
Thanks a lot for your help!
BP937215695315
Hello, I bought a Punto without the radio Code. So i would be glad if you could help me.
Here are the details of my radio.
Prod. Nr. Fiat 735 289 639
BP937215358033
honk6420;)
code autoradio
i changed the battery of my punto 2002 and i don't have the code of autoradio
number serie is: BP237434031421
model number is: 7642374316
punto cc
Can you help me please :D thanks much
