OK bit of an update, as per previous post, all cam oil ways clear, cam box oil ways clear etc etc. I had a quick look at the valve clearances and to be honest they are on the limit mostly, some just over, but as you know, bucket and shims don't just get noisy, they wear over time or get vocal if starved of oil. one is definitely a little larger than spec but that's the one I have always heard since we've had it. It ticks away quietly to itself and never changes, it not really noticeable but it is a little louder than it's stablemates. however I checked the smoothness / ovalness (if that's a word) of the buckets, all perfect fit , no sticking ones when I spun them around, no slap, spun them all around and could pull them up a tiny bit until they touched the cam lobes, put it back together and there is a distinct difference to the sound, it's not SO 'knockie', in fact after a run round the block and ten mins of idling and the fan coming on its I would say 95% how it's always been, I can make it a TINY TINY bit 'knockie' if I hold it at certain revs but THE Air cleaner is off and the bonnet open so just could be I'm hearing it in an unusual fashion, inside driving by the way it's silent, can't hear anything. HOWEVER.....
I drove the wife's panda today identical to mine, in fact they could have been next to each other on the production line. Came back to it after an hour, started it up and just for curiositys sake I did the hold the revs at 1200 rpm and guess what? It has the same sort of tapping/clickety sound albeit about 30% of what I've had in volume, it's as if this new ' no spray bar cam oil feed system' has to prime itself first for 30 seconds or so, from cold both cars are silent..... BUT and its a big but, I have a little confession..
I have a couple of 60s British bikes, well I've just sold one actually, and I did a 750cc conversion on one a year back, a morgo big bore kit, and the running in instructions is to use a none detergent, 0-w40 mineral oil to help it 'bed in' after fitment, I did as instructed and the running in process went well but I noticed it rattled its bits off something chronic, it did have a slightly worn tappet block that I didn't replace due to lock down restrictions at the time but as it was running quietly beforehand I just put it back in. After a run when up to temperature it absolutely sounded awful, I'm talking like it had no oil in it. They should run on 20w-50 classic oil but the warranty on the morgo kit specifies 0-w40 mineral or any warranty is invalid...
Fast forward to earlier this month and I needed to top up bumble before a trip to the northeast and back.....
Now then, I reached for my normal 5-w40 C3 stuff we use on both cars but it was more or less empty, well a couple of eggcups full at the most, I then reached for another container and wondered why I had put about a litre of oil in a clear container, assuming it was left over from the other pandas oil change.. I topped up with about a mug full, went on holiday, never missed a beat all was fine. Cut a long story short
I was idling somewhere waiting for something and I thought bumble sounded a bit tapperty, I revved her and thought that's way louder than normal, cr@p, had I put some of the 'death oil' in that has possibly turned my bike into what sounds like two skeletons bonking on a xylophone? I got back and looked for the old tin of motorcycle oil but it had gone, I really can't remember if I've decantered it into a clear vessel and thrown the can away....
Whilst coming out of tescos last week I revved it just as I was under the tunnel and it sounded very tapperty, did In fact top it up with the 'death oil'? it was due a service anyway so I changed the oil and filter and this made a difference but my conclusion is some of the 'death oil' will still be in the engine, even after a thorough hot drain (in the oil pump, in the crank, cam, block galleries etc and clinging to the inside ) so after spinning the bucket shims around and blowing out to check clearance of the cam box oil ways and it then making a big difference to the sound I'm convinced it's the remnants of the 'death oil' still inside, that would explain the noise was only happening on a warm/hot engine, no oil light on, no smoke and it performing a 1000 miles of motorway work faultlessly in the past month or so.
I will maybe drain what's left in again next week to try and get rid of the remaining incorrect oil.
I will keep you posted
