Technical Τhe car turns off and on when on the road
panagosr
greece
Hello!
I have a Grande Punto 07 diesel 1.3 90hp.
Εvery day that I use the car when I'm on the road, all the electrics turn off for a second and then everything comes back on.
I have changed batterie with new one.
What else could be wrong?
It is dangerous because it goes out for a while suddenly
My advice would be;
1. Stop using it.
2. Read the fault codes - ask your local garage if they can come and read the codes or buy a cheap compatible reader.
If there are error codes logged then it may give you a clue to the issue.
Good luck.
Hello!
Hi 🙂
Change the Black Earth cable from Battery to Chassis and engine 😉
They can fail inside.. No longer passing electricity 😕
