diego74
Milleage is stored in eeprom (95040), that is why I suggested that, take a look:
Most likely they will do what I suggested.Thanks for your opinion.
I'll search for a workshop for repairing the dashboard.
Thanks a lot...Most likely they will do what I suggested.t
Thanks for the info...1) Abrir programa
2) Click en el botón con el signo de interrogación verde, asegurarse que detecte el chip (muestra un listado, seleccionar M95040, si no lo detecta no está bien conectado)
3) Click en el botón con la flecha verde (Leer)
4) Guardar el archivo en la PC con el botón del diskette.
Then change eeprom and write the saved file with the icon with the blue arrow, you can verify the written data with the green equal sign button.
Thanks a lot...To connect to the CH341A here, you use the clamp wich comes with the kit?
Yes, pin1 of the eeprom (leg below the ST logo) matching with the red stripe of the clamp.Thanks a lot...To connect to the CH341A here, you use the clamp wich comes with the kit?
How you do it?
Ok ..I bought the dashboard and the CH341A and I'll try.Yes, pin1 of the eeprom (leg below the ST logo) matching with the red stripe of the clamp.
