Communicator
Prominent member
- Joined
- Aug 3, 2019
- Messages
- 3,405
- Points
- 930
Thanks a lot for this....Despite several attempts I have never succeeded in locating the cooling system bleed nipples on my 2006 2.8jtd.
The refilling procedure may be seen here.
Yes, there's a plastic one .How did you do the bleeding? You sure you got all air out? Did you find the breathers?
Can you explain a little how to do that exactly?Fit a new wire between the engine and the body - see if problem gone
Yes, it can be.I think there could be a problem with the ground lead between engine and body /chassis
Anywhere that's clean metal on engine to anywhere that is clean metal on bodyYes, it can be.
It 'd be good some indications on how attaching the new wire.
Where do you think are the best places for this??
Don't you think if the wires going from negative battery pole, one to engine and the other to chassis, are well attached it is not enough??Anywhere that's clean metal on engine to anywhere that is clean metal on body
I have read these usually tend to get rust on these vehicles (saw some pics as well), so you can check in e-Learn the earth points and make sure the ones affecting the dash are clean (there is a schema showing each component is connected to which earth point), also you can put some contact cleaner in the dashboard contact or check with a multimeter that you have a good earth on its respective wires.Don't you think if the wires going from negative battery pole, one to engine and the other to chassis, are well attached it is not enough??
That reads like you are being very rude.Don't you think if the wires going from negative battery pole, one to engine and the other to chassis, are well attached it is not enough??
For sure...That reads like you are being very rude.
Corrosion of the wire and the crimp connections and the contact points can cause problems.
I don't think he's rude. Mind you, he's writing us from Spain, might be a language thing that made you read as rude.That reads like you are being very rude.
Thanks for the indications.I don't think he's rude. Mind you, he's writing us from Spain, might be a language thing that made you read as rude.
@MKUser, I tell you what. The bleeding can be tricky sometimes and even if you do as the manual says, sometimes that is not enough. Do this to make sure you bleed it good. Park the car with the front wheels on higher ground, so the breather on the radiator becomes the highest point in the cooling system (except the expansion tank). Open the breather and watch if air comes out (coolant and bubbles). Take that breather cap out completely and see that only coolant comes out, no bubbles. If you need to, put some more coolant in, until no air comes out if breather. Put the cap on. Fill the tank to max and take the tank's cap out. Start the engine and warm it up, revv it to 3000 RPM like before. That should do it.
How old is the water pump? Is there any chance it is off? If the needle shows you hot temperature, test by hand the hose next to the temperature sensor. Is it the same temperature like the one next to the radiator or hotter.
After the engine is running, if you take off the expansion tank cap, can you feel that there is pressure? It could be a water pump problem or even that cap if there is no pressure. The cap has a valve to release pressure, if it's broken might be open all the time and if so, the system is underpressured.
I don't think it's a ground problem, but do all the checking you can, to make sure.
I did it with the engine stopped, only putting the contact key on, to see error messages.And how were the temperature readings?
