Hi all.
I'm owner of 2003 Ducato 2.8 JTD. Today I noticed really weird behavior of my temperature gauge. Please let me describe in details:
Making it short - everything seems to be perfectly OK, except gauge displaying worrying values. So I've connected OBD2 scanner (ELM327), installed few apps on my phone to get some readings. Two apps worked, both gave me temperature reading of 215°C - obviously completely awkward value. Well, intake temp reading was 215°C too. Interesting... No error codes found.
I know I should use Fiat EcuScan for gathering more realistic data, but the issue appeared while being about 5000 km from home, so no way to do it until I return
Please share some thoughts - gauge died, poor instrument panel soldering, temperature sensor died, thermostat died, faulty wiring or what?
Thank you in advance!
- During normal motorway driving the needle suddenly went from half of the scale (normal position for warm engine, just below half mark) to the red area. Not exactly to red, just touching its lower part.
- I've made a quick stop to cool the engine. After switching the engine, needle drops to bottom, as usual. After 15 minutes of waiting, I've turn the engine on, needle immediately went to the previous position, touching red mark. Apparently cooling didn't work
- Of course I've checked everything possible - coolant level was proper, temperature of reservoir tank was proper (warm, but far from being hot, easily to touch), no excessive pressure in reservoir tank, cooler warm, but not hot. Hoses in normal condition, excessive pressure. No leaks at all. Didn't manage to reach thermostat though. Engine didn't seem to be unusual hot by touch and/or smell.
- Fans did not start at all.
- No loss of power, no limp mode etc.
- Model
- Ducato 2.8 JTD
- Year
- 2003
