C chalkie1 New member Joined Aug 29, 2009 Messages 8 Points 5 Location northfleet kent Nov 24, 2009 #1 I own a 2001 sei sporting and every time i go around a right hand bend i get a metalic tapping noise from the right front wheel area,perhaps the outer drive joint if so how easy is it to fit.
fingers99 Patron member Parked in the garage Written a guide Joined Mar 20, 2006 Messages 27,743 Points 4,560 Location Liverpool Nov 24, 2009 #2 Does sound like the outer pot joint. Easy enough, but probably easier still to fit a known good driveshaft. All in the Haynes.
rallycinq Autotest Special Parked in the garage Joined Mar 19, 2002 Messages 24,592 Points 3,862 Location Lake District....Moist Nov 24, 2009 #3 Commonly refered to as a CV joint. Easy enough to do whether you do the shaft or just the joint. Cheers SPD
