I havn't got access to the stilo elearn cd here but
I always use a torque wrench to fit spark plugs
didn't matter too much on a cast iron cylinder head
but on an alloy head it's easy to strip the threads
by over tightening.
Have a good look at the threads in the head to ensure
the heated gases have not damaged them fit NEW
spark plugs to be on the safe side and the guide below
is a rough guide lifted of the internet but just be careful
of damaging the head - even after 40 odd years of fitting
spark plugs I still dislike doing so.
Installation Instructions
It's easy to check, clean or replace spark plugs, by simply following these procedures.
First leave the engine to cool.
Twist and pull off the spark plug lead. To ensure you don't alter the firing order we advise you to remove one plug at a time.
Slacken the plug and clean the recess if necessary.
Screw in spark plug by hand until it is seated in the cylinder head.
New spark plugs with flat seats are then tightened by a further approximately 90 degrees using the appropriate spark plug wrench.
Spark plugs with conical seats as well as used spark plugs with flat seats are screwed in by a further 15 degrees approximately.
Re-attach the spark plug lead.
Repeat the procedure for every plug.
John
