General  How do I click the inside boot panel back on?
skrrt
Hi all :)
Today I was trying to remove the knner boot panel. I removed two screws and two bolts and could click it off. When I tried to click it back on it did not seem possible as the white "pyramids" are of an inflexible material. From the looks of it the panel should be bent or slid in from the side, or am I missing something? Image attached.
Thanks a lot in advance. This is frustrating me.
Either remove the "white pyramid') ? and slide
Over channel slot and then press on, but you stand a good change to break it since by now the plastic jas become brittle.
You can get new ones from a spare shop if it happens.
Or you will have to remove the bolts and slide it in while.
Thanks for your swift reply! Which bolts exactly?
The slots for the clips have an open end, which is Gods hint that the clips have to be eased into the slots first... then the panel is pushed home, to seat any other clips (these others would be the usual "fir tree" style). The screws would be the last things to go in.
Ralf S.
I fixed it today. Your tip worked great! Thanks a lot.
