Technical swivel hub bolts
Cheadle Staffs/Luf Leics
Current lyin the process of dismantling the front of the car to get at the clutch, I can't get the two bolts circled in the attached image to come out, are they threaded all the way through the housing or does the thread end part way down the shaft? If it is part way down the shaft it's blowlamp time :devil: If not, I'm open to suggestions!
having ripped an engine out the other day, undo the shaft nuts, undo the ball joint pinch bolt, pop out the bottom ball joint then use a hammer to pop the shaft out of the front hub
