Technical Sway/anti-roll bar links
nigelvan
Belgium
I'm attempting to change my sway bar/anti-roll bar links (I'm not sure what the UK word for it is). It should be an easy job according to e-lean. Unbolt 1a and unbolt 1b, like always it doesn't go according to plan:
On both sides the bottom nut to the wishbone comes of rather easy with a breaker bar/impact wrench. But the nut to the sway bar itself doesn't budge. I've tried penetrating oil, WD-40, breaker bar and different impact wrenches. I've also causiously heated it with a heat gun, making sure I don't melt the CV Boot nor the rubber bushing. I'm kind of out of ideas, it seems like the nut is welded on. Anyone out here who faced the same issue?
IMAGE 2025-07-05 14:26:13.jpg
Model
X250 3.0
2007
You may have to persevere with oil and heat. Clearly snapping the the threaded part off the anti roll bar would be bad.
If you are really determined to replace the anti roll bar drop links you may end up filing or grinding through one side of the nut and then using a chisel.
Best wishes
Jack
I borrowed a battery impact wrench. I bought one straight afterwards as they make this and many other jobs easy. In UK they are cheap things and worth every single penny. Top nuts on struts for example just spin off as well as the anti rollbar links. Usefulfor caliper carriers and wheen nuts. I only ever use the torque wrench for final tighten now.
I did try a battery impact wrench.
Best wishes
Jack
Yeah, I'll let it soak for a few days. I got the advise elsewhere to use a chisel to hit one side of the nut so it will open up a bit. I don't want to damage the threads or snap off a piece of the anti roll bar... so patience I guess.
Update: after letting it sit and soak for a few days the nut finally came off with the impact wrench. But, the link itself is stuck all the same on the sway bar. I've been hammering it all day but it doesn't move.
Yeah, good plan. First I'll drive a bumpy road with the nut screwed on loosely, it might come loose. My yearly inspection is due in a few weeks so I'll go there first with the old links (don't think they'll bother about that) so I don't have to stress when damaging something major and missing the deadline.
So, actually inspection found the real issue: a worn out ball joint (yes big rookie mistake from my side).
Since then I've been driving around with loose nuts where the sway bar link connects to the sway bar (just gave it a few mm so they could break loose). Nuts are obviously optional since those links are going nowhere. I'm wondering if it's even worth the hassle grinding them off, since the rubbers are still okay and I doubt it will impact the stability the slightest bit.
If rubber parts ok then they are ok.
replacement parts will not lady as long
