Anyone experienced their drain plug leaking? There's a slight weep of oil coming from mine, despite it being tight/torqued up correctly, it's an aftermarket sump but the design is the same, using a washer less drain plug basically.
Apart from using some PTFE tape on the threads, any other ideas, what did you use to seal such a leak?
