Gman88667733
- Joined
- Jan 11, 2020
- Messages
- 410
- Points
- 89
I've taken that on board. Hopefully purchasing the other side strut from that exact car the current one is from, so both still be the same age (approx 1.5 years old)Just caught this thread, been away from the computer for a few days.
First concern was the use of a used strut. Never a good idea as its history is unknown. Also struts should be replaced in pairs, to ensure balance, otherwise handling can be compromised.
Sourdce of a used strut will be from a scrapped car, either due to rust, not many rusty Pandas yet, serious mechanical failure, not many of thosse either except perhaps high miles diesels with broken timing chains, or crashed.
A strut that's been in a crash may be compromised.
Springs are different between 1.1/1.2 with or without aircon, diesel is a heavier spring, Twinair probably different again. Whilst damping rates will also be different with OE struts for those variations, aftermarket struts may all be the same for all models, however, one manufacturer may differ from the next, reinforcing the need to fit pairs.
To safely use a used strut, you need to be sure it is of a similar age and wer to your other one, same spec, wither OE or same manufacturer if aftermarket, and using the same strength spring.
If your car is unsafe as a result, the consequences might be horrendous.
Replacement top gaiters and bumpstops are available. A real pig to assemble, needs lots of lubricant. https://www.shop4parts.co.uk/?name=store&op=Product&ProdID=7101
Rattle at the front end is very likely to be the drop links. They make a tremendous noise whilst feeling tight when prodded. Removal will show how worn they are. They are cheap and easy to replace. Do a pair, not singly.
The rattling stopped when I changed the first spring.
Edit - just have purchased the second strut. Will fit it as soon as it arrives
It'll have matching ones then. Should've done it in the first place really, my mistake
