Hi there- First post, but you all seem a helpful bunch and hope you can shed some light on a problem a friend is having with his 1997 Brava 1.4S.
He drove the car to work last night and parked it up in the local NCP. All was fine.
This morning when he went to go home, the key will not turn in the ignition. It will turn enough to unlock the steering lock, but will not move past there and seems jammed solid. For the steering to remain free, he has to hold the key as far as it will turn, or else it will lock again. To get the key back out the ignition, he has to turn the steering until it locks, then wiggle the key.
The strange thing is it will turn fine to the Park setting for sidelights, but doesn't turn the other way (Not even far enough to light the dash lights).
Obviously, it's either a problem with the steering lock or ignition barrel.
When turning the steering wheel with the key turned as far as it can go the steering will occasionally lock and other times make a clicking noise which you can feel on the key.
How would we go about fixing this, and why should it be fine the entire time he's owned it, then suddenly catastrophically fail like this?
At the minute the car is stuck in the NCP until he can get it recovered, so any tips, suggestions or ideas would be highly appreciated!
Thanks in advance,
Ewan.
Thanks in advance,
Ewan.
