NickBr
- Joined
- Jan 26, 2019
- Messages
- 61
- Points
- 89
Lately I have a problem with the engine idle rpm.
It is not something that constantly presents it, but it presents it when it warms up.
Engine rpm goes up and down to 3000 rpm, but even though they are up, the engine does not seem to have the same power.
For example, when I accelerate with the accelerator pedal I have an acceleration and the car develops a certain speed.
If while the engine increased rpm (eg 3000 rpm) I select a gear in the gearbox and release the clutch, without pressing the accelerator, the rpm fall close to idle and I have no power to accelerate or slide the car, just like as if the engine rpm are virtual .
I have removed and cleaned the throttle body but saw no improvement.
The stepper motor that regulates the engine idling moves smoothly without any problems and does not get stuck at any point.
Below I show you in a video the problem
At the points of the video where the rpm go above 3000 are because I press the accelerator pedal.
