Hi all,
Hoping you can help! I recently purchased my first car, a Fiat Stilo JTD Dynamic, 1.9 Diesel (51 Plate, 5dr) and I'm having some problems with it.
I come from a long line of Fiat owners so I know Fiat's are good cars but this one seems mega problematic.
the problem is this - the heater in the Stilo is a climate control one but it's not working correctly. Everything works as it should (i.e. the fan makes a noise and adjusts, the buttons all work correctly and you can hear the blower change when you put it on the feet/screen etc) but there is basically no air coming out of the vents. Regardless of where the air recirculation setting is pulling air from the outside or recirculating the air, nothing comes through.
I took the panel underneath the glovebox off to have a look and see if the motors and cogs are working and, with the help of a friend, tried all the different setting etc & everything was moving and shaking as you would expect but still no airs comes out of any of the vents.
Finally, the car went into Fiat last week due to having an ABS/EBD/ESP warning light on the dash all the time and I asked them to have a look at the blowers, they said that, on the diagnostics, everything is working correctly so the only thing they could do is replace the heater motor and fan for £370. In my opinion the fan etc is working because you can hear it going but I just don't know what is going on.
Anyone had similar problems? Can anyone offer me any advice?
Any and all suggestions will be gratefully recieved! :worship:
Dan
Dan
