Hi
The front wheel is obscuring a good view.. but access is ok with it still there
(Just a plastic cover in the way..)
Once the belt is removed from pulley..
You can spin the alternator by hand.. then turn it slowly..feeling for a notychness..
Should be all smooth and free spinning..
I find this simpler than attempting to slacken and retension the belt in a conventional 'undo the alternator' way
This keeps the tension 'as set'
The pulley is held on with 3 bolts..and there is a very small hole in 1 position
This lines up with a tiny pin
Thats your alignment
Images all over the forum.. FIRE engine been around for decades
'Heres one I prepared earlier..'
https://www.fiatforum.com/panda-guides/437184-panda-8-valve-cambelt-change.html?437184=#post4158423
You were right, wish you had given this advice at the beginning.
I put the new starter motor in (arrived yesterday afternoon) and it struggled.
So I did exactly as you said (removing the pulley) then put the belt to the side and replaced the pulley (with 3 bolts) and the car started first time.
The alternator does not move at all.
Thanks for the good advice.
However now the alternator seems very difficult to remove as I have an aircon motor above the alternator in the way of the top bolt.
Any suggestions on how to replace this alternator?
Thank you for educating me on repairing the Panda.
Regards
Tim
