My 02 Multipla speedo is reading well under compared to my GPS. I don't mind over but under is not great. Is calibration something can be undertaken by an amateur or do I need an auto electrician?
			Have different sized wheels a d tyres been fitted then the factory originals?My 02 Multipla speedo is reading well under compared to my GPS. I don't mind over but under is not great. Is calibration something can be undertaken by an amateur or do I need an auto electrician?
Really must of had some bad cars I've compared by to the GPS on my phone and satnav it's around 3-4mph out at 70 give or take a littleMy experience of Fiat speedos is they are outrageously inaccurate. A good one is inaccurate and a bad one as in my newest Panda is a joke. If you have a consistent steady error you'r in luck and may be able to adjust the needle. My worst experience was a Renault many years back which said about 75mphat full speed. it was in fact going north of 100! That was a faulty speedometer caused by the sensor at the end of the cable failing. Check that you dont have a similar issue. Try plotting the readings against true speed at all speeds from 5mph up to fast speeds and see if it is accurate at any point.
Yes, indeed, any idea how to adjust the needle?My experience of Fiat speedos is they are outrageously inaccurate. A good one is inaccurate and a bad one as in my newest Panda is a joke. If you have a consistent steady error you'r in luck and may be able to adjust the needle. My worst experience was a Renault many years back which said about 75mphat full speed. it was in fact going north of 100! That was a faulty speedometer caused by the sensor at the end of the cable failing. Check that you dont have a similar issue. Try plotting the readings against true speed at all speeds from 5mph up to fast speeds and see if it is accurate at any point.
mine is 63mph = indicated 70. 67 is indicated 80. Its really irritating on a long run where Iwant to keep the speed up. Doing say 62 -63 or around 74 -75 real speed has the nervesReally must of had some bad cars I've compared by to the GPS on my phone and satnav it's around 3-4mph out at 70 give or take a little
The previous 500 I was around 4-5
I would imagine its remove the panel, then remove the 'glass' then carefully mark the position its in and the needle hsaft , remove the pointer and replace in a better position. It would be easier to obtain another instrument cluster. The alternative would be to get some black paper or plastic and mark the speeds on that and stick it over the existing markings. On the Panda it couldnt make the speedo look worse than standard!Yes, indeed, any idea how to adjust the needle?
