The faster you go ... the higher score you get .,. if you get a high enough score you have to hand your licence back in (Y) then its game over
Manufacturers generally take the wheel/tyre combination with the largest rolling radius and calibrate as accurately to that as they can. Other wheel/tyre options may give smaller rolling radii, so giving a higher speed reading. Mostly you will find that the smallest to largest will be within the 10% allowed, so only one calibration per model. Years ago it was common to have a different speed drive gear for steel or alloy wheels on the same model.:yeahthat: they always read fast, newer ones are more accurate than older cars but they all read fast. Only way they wouldn't is by putting larger than stock rolling radius wheel & tyre combo on a car but that often corrects it rather than making it read slow....
My old alfa 159 was pretty accurate but was about 2-3mph off what GPS said, my cinq says 100mph when your really just over 80mph.
It would need to have a transmitter inside and a SIM for the mobile phone network. Can't see Navman paying for that for every unit. And for how long, and for what purpose?How do you know it isn't.
There must be a reasonable amount of leeway on these average speed cameras. For instance, the ones on the M60 between J24 and J25 include quite a significant right hand bend over a fairly short distance. I don't have figures but driving in lane 3 must be a shorter distance than lane 1 therefore, even if the cameras are aimed at slightly different points to allow for a shorter or longer distance between start and finish of the limit, what happens if you start in lane 1 then move to lane 3 in order to overtake?today driving down the A465 that i mentioned before in this thread that has average speed check on it. I did notice that some sections start with single lane and end in dual lanes and vice versa, for them to work at all scout has to be right.
When the average speed cameras first came out they did in fact only record people that stayed in the same lane but the software/technology is such, now, that you can weave as much as you like but you'll still get caught.
If you want to get Orwellian on us every single vehicle with a Sat' Nav' can be be tracked.
People whinge about all these cameras following our every move
My speedo is +/- 10mph inaccurate, the faster you are, the more inaccurate, I usually have to guess with the rev counter (since I know my car that well), which for some reason has been funny lately.
Either way, when I see a camera, if my speedo is at 70 for example, and the limit is 70, I'll slow down 60.
I also would think most people who have working speedos will slow down when they see a camera regardless of their speed just to make sure
+ any mph on a speedo is BS. The spec +0/-10% (most are even better than that). That means if you haven't changed the rolling radius of your wheels you will NEVER be going more than 70mph if the speedo is reading 70mph. To then slow to 60mph (in a 70mph limit) at the sight of a speed camera is just madness as your inviting a rear end shunt.
Rather not have 3 points really
So you'd rather have 6+ points for dangerous driving instead then? Because that's what would happen if you cause an accident.
If your doing an indicated 70mph in a 70mph zone you won't get any points because your actually doing about 67mph. (check it on a GPS speed device )
Isn't it 10 present Lee way anyway? So the limit would be 77? I've never really known
No, police guildlines are not to prosecute below the limit + 10% +2.
Police forces do not have to adhere to this.
Dom
So actual cameras are set dead on to the limit? And aye I can't imagine the typical policeman round here to listen to that haha
No, they will be set to whatever the force chooses to, it could be 70 all the way upto 77.
Seriously, go for a drive with your sat nav on and check the accuracy of the speedo.
Dom
Ahh I see thanks for clearing that up for me.
And it varys I don't really want to get into it especially on this forum as I could say what the speedo actually does and if it doesn't conform to someones logic on here then I must be lying.
Same as to why 5th gear has randomly dropped 500 revs recently, I'm apparently seeing things
