One near side wing - DONE
One off side wing - DONE
Bolt for the under car exhaust heat shield - No, see below
4 steel wheels - DONE
One near side drive shaft - DONE (see below)
Both suspension arms - Got the near side, CBA with the off side.
Internal handle/ coat hook - Done, see below
Near side wheel arch liner- DONE
Off side wing mirror - DONE
The front bolt for the exhaust heatshield..... seems not to be a bolt. I checked on my dad's car.. and it seems to be a rivet, rather than a bolt or screw. Can anyone shed any light on what this is? Is it easy to get a replacement for this?
Near side drive shaft - will the drive shaft from the 5 door 903cc Uno 45 fit my Uno Fire? It seems to be roughly the same, but the part that goes into the gearbox doesn't seem (to the best of my memory) to be exactly the same. Is this correct, or am I just tripping and it will work fine?
Internal handle/coat hook - I took the handle off with no problems, but the one the bit that somewhat confused me. There seems to be a metal 'plug' that the screw... screws into. However, this plug appears to be inside the chassis, with no possible way of removing it. it does wobble around, but it is if it was put into the frame, and then the rest of the chassis was welded together, meaing that the plug doesn't seem to be able to come out.
Can anyone shed some light as to these points please?
All the other bits are off the car now, which seems to be getting lighter and lighter! By the way, dad has said that if anyone needs any parts from it, they are free if you come and collect them. If you need anything, let me know and I will check that it is there before you set off, as well as giving you my dads address before you set off too
Its a Mk2 5 door black Uno 45 if you are interested - Jai, Chas, you two are the most likely to need bits, so just let me know. It's only in Harrow anyway so not too far from you.
