if the smell is there with the heater on, it's more than likely down to the heater itself. check for a leak around the heater matrix where the pipes go into it. could be evaporating coolant perhaps? i don't know about the punto, but the tipo has a tap which tends to leak it may be something similar.
Hi, there is supposed to be a pipe connecting the two, you can pick up a replacement from halfords for about £2, it might make a difference as i noticed that when my downpipe was blowing i could smell it coming from my engine bay, worth doing anyway as it re-circulates hot air into your intake therefore improving fuel economy.
Do you have the sweet smell in your car?I get the eaxct same exhaust fumes smell when i turn on the heating in my 96 punto 1.1s
I have a hole underneath my airbox but there is no fitting on the manifold for a pipe to clip on to?
Today I was out for a longer drive.
And after reading about this here on the forum, I thought it smelled a little bit sweet.
I got a friend of mine to sit in car, and he said it smelled a bit like cooler liquid.
But I checked the cooler liquid container, and it was full (actually a lot full. See attached pic.)
The picture was taken after a drive. I had no idea that the difference would be that big.that is way too high,
It's not going to do no harm though, and is better than too little
it not going to cause too much pressure, blow heater matrix and make funny smell in the car then?
do puntos have taps on the heater or is it constant heat, and the air redirected upon the temperature setting?
