Technical  Slightly higher ground clearance.
EMCPanda
Switzerland
Hello Pandaliers
I would like to gain some ground clearance on my 2013 4x4 mainly due to the amount of time I drive in quite deep snow.
Does anyone know what the options might be here to achieve this?
Thank you!
If you are in Switzerland you need to be aware a lifted car should not be able to pass state inspection.
Hello. The annual test is called the MFK here and you are correct to say that a “modified” vehicle will not pass this test UNLESS the modifications are registered in the vehicles paper work and passed as safe.
