Hi All, well everything has been quiet for a while but then today the EML came on after a 30 minute drive. A quick scan showed two fault codes P0226 & P0238
I’ve had the P0226 before and did contemplate replacing the accelerator peddle/sensor but didn’t; now I’m wondering if it’s time? This time it felt like i was having to press the peddle more to get the same amount of output
The new code was P0238 Air supply circuit anomaly. The suggestion seems to be the MAP sensor?
I cleared both codes and went for a test drive and all seemed normal, so the question is how regularly do these fail and is there a brand that i should look for to replace them with?
TIA
TIA
