So new problem
To start with, when opening door, instant pumping to around 48 bar in the accumulator.
Ignition on, "Gearbox Failure" light up on the dash, and sometimes leaves gearbox icon on dash, and sometimes not. But will pop out with "gearbox failure" now and then, until shut off.
Pump is making sure the pressure is kept between 43 and 50 bar at all time.
When trying to read fault codes, nothing shows up.
And im stuck with a car that only will stay in neutral at all time with motor running and not running. Will not even try to engage gear, and then fail..
Read up on alfa forums, and here, and my head is empty for ideas to try now, with what must be considered a working pump, accumulator keeping and ok pressure for the look of it.
Selespeed oil is topped of it looks like had mechanic to do that, but when looking at the retainer where is the MAX at, is where the "container top starts" in the corner of it?
