right, been the best morning for a while so i thought i would do some tests. pulled the plugs off the ecu, tested for continuity from ecu plugs to lambda plugs, no problems. then i tested the lambda sensors for resistance and voltage. now the tester i have is only a cheap one so as for ohms test it had to be put on 20M for me to get a reading, now the reading i get is 18.17 with it out of the car and cold, in the car when hot i get a readin of 6.3 on the 20M ohm setting and a voltage of 0.03 - 0.04 so i can aasume the lambda sensor is at fault. i have tried the tester on my glanza and with the lambda sensor on that unplugged the voltage sits around 0.9v so i know the tester is ok. does the lambda sensor use the exhaust as an earth?
