Here is the latest addition:
Hmmm. Some inspired driving perhaps? It's a good effort to break the diff. Shows how much torque you are developing. It's running too well!
Rebuilt box with straight gears from a specialist has got to be well over £1000 these days. Have you got a price? Doesn't seem worth it to me, unless this is going to be a really long term relationship.
As far as a new differential goes, the box is a unique type I believe as no car other than the 127 got the Brazil OHCs. I don't have my technical manual anymore and my memory of my Y10 Turbo that never was is fading, so I can't remember what actual gearbox it has now. I reckon it will be a normal Panda/Y10 box with a special bellhousing? In which case a diff will be easy to find, and a cheap fix. Got any pictures or do you know?
If Damon hasn't got NOS competition for me, I'll be staying at home on Halloween!
Its just a FIRE gearbox with a different bellhousing. I believe the ratios or the final drive may be a little different but it shouldnt be hard to get it mobile again.
The idea that a stronger box is needed does make sense. The truth will out shortly I suppose. Perhaps the standard Marbella box is a different type to the Panda as well?
If Trevor can remember it all, he would still be the man to ask! I'll keep quiet until there is some facts on the table!
Crazy! That gear looks like reverse or more likely the reverse idler. That doesn't bode well for the general state of the inside of the gearbox I have to say. Proper job.
So it did fail where you thought. Does make a lot more sense than what I said, but I didn't know you were fishing in the diff area! Can you get some pics of the gearbox, so we can perhaps identify any common parts?
So it is a Panda box. That's good I suppose. I would just re-assemble as you can with what you have. If the box is changing OK otherwise, then sod it. It's not exactly awful to have to take the gearbox off again if this happens in the future? There are much worse jobs. Presume you kept engine in the car?
any updates?
