;* Project:    Fiat Seicento RPM counter    *
;* Author:    Nebojsa Mrmak            *
;* Date:    04 Feb 2008            *
;* Note:    Check out www.fiatforum.com    *
;*        for more information        *
    ORG    0000h
    MOV    SP,#030h        ;stack pointer vector
    JMP    INIT
    ORG    013h            ;interrupt that occurs when a pulse is detected
    JMP    PULSE
    ORG    01Bh            ;Timer 1 interrupt vector
    JMP    INT_T1            ;Jump to the timer1 interrupt routine
INIT:                    ;initialize our stuff
    ORG    100h            ;program start vector
    SETB    PX1
    MOV    TMOD,#00010001b        ;establish T1 as a 16 bit timer - at 12MHz ~ 0.1s
    MOV    IE,#10001100b        ;enable ints, enable T1, INT0 int.
    MOV    TH1,#11111101b        ;reset the timer
    MOV    TL1,#11110000b        ; -||-
    ;init some values here:
    MOV    P1,#1
    MOV    R0,#0
    MOV    R1,#0
    MOV    R2,#0
    MOV    R3,#0
    MOV    R4,#0
    MOV    R5,#0
    MOV    R6,#0
    MOV    R7,#0
    MOV    0018h,#0
    MOV    0019h,#0
    MOV    001Ah,#0
    MOV    001Bh,#0
    MOV    TCON,#01010000b     ;start the timer
MAIN:
    ;The following four blocks are used to display the numbers on four 7-seg displays.
    MOV    A,#0
    ACALL    MASK
    MOV    P1,#0
    MOV    P0,A
    MOV    P1,#1
    MOV    A,0018h
    ACALL    MASK
    MOV    P1,#0
    MOV    P0,A
    MOV    P1,#2
    MOV    A,0019h
    ACALL    MASK
    MOV    P1,#0
    MOV    P0,A
    MOV    P1,#4
    MOV    A,001Ah
    ACALL    MASK
    MOV    P1,#0
    MOV    P0,A
    MOV    P1,#8
    ;and repeat.
    JMP     MAIN
INT_T1:
    ;timer overflow interrupt!
    PUSH    ACC
    PUSH    PSW
    CPL    P3.0    ;just flash a debug LED, safe to remove this line
    MOV    A,R0
    ADD    A,#10
    JNC    NO_OVERFLOW
    INC    R1
NO_OVERFLOW:
    ;if the low byte of the timer is still less than 255
    MOV    R0,A
    POP    PSW
    POP    ACC
    RETI ;end timer overflow interrupt here
PULSE:
    ;ecu LT pulse interrupt start!
    MOV    80A7h,#10101011b ;reset the watchdog timer.
    ;delay a little, debouncing while i was testing it with a button.
    ;Possibly safe to remove when in a car, ecu shouldn't have bounce.
    MOV    R7,#10
LOOP:    MOV    R6,#10
    DJNZ    R6,$
    DJNZ    R7,LOOP
    ;end delay
    JB    P3.3,NEXT    ;if button is still pressed, do the interrupt
    RETI            ;else return from interrupt
NEXT:
    MOV    TCON,#00000000b        ;stop the timer
    PUSH    ACC
    PUSH    PSW
    MOV    P2,R0    ;debug, outputs R0 value to port 2, safe to remove this line
    MOV    A,R0    ;push R0 and R1 onto the stack
    PUSH    ACC    ;R0 and R1 hold the number of times the timer overflowed x10, and since it overflows once each
    MOV    A,R1    ;1ms, then it's the number of ms passed between 2 revs
    PUSH    ACC
    ;the following block practically divides the timer by 66
    ;(max. value the timer can achieve is 666, so you get 1/10 of that value, and the max is 0.001s)
    MOV    A,TL1
    MOV    R2,A    ;move TL1 to r2 (TL1 - timer 1 lower byte)
    MOV    A,TH1
    MOV    R3,A    ;move TH1 to r3    (TH1 - timer 1 higher byte)
    MOV    R1,#66    ;move 66 to R1 and 0 to R0 so we can divide
    MOV    R0,#0
    LCALL    div16_16    ;call the division routine (borrowed from someone else)
    MOV    A,R2    ;put the lower byte of the result into 0018h
    MOV    0018h,A
    POP     ACC    ;pop R1 and R0 from the stack
    MOV    R1,A
    POP    ACC
    MOV    R0,A
    MOV    A,R0    ;add the calculated number of ms on the timer to the number of overflows
    ADD    A,0018h
    JNC    NO_OVERFLOW1
    INC    R1
NO_OVERFLOW1:
TEST0:    ;a small test to see if we're going to divide by 0 (we don't want that)
    CJNE     R1,#0,TEST_END     ;if either register is non-zero, carry on
    CJNE    R0,#0,TEST_END
    POP    PSW         ;if both are zero, pop the values from the stack and return from interrupt
    POP    ACC        ;better to give up here than divide by 0, we'll get the rpm on the next 2 pulses
    RETI
TEST_END:
    MOV    A,R0
    MOV    R2,A
    MOV    A,R1
    MOV    R3,A
    MOV    R1,#11101010b
    MOV    R0,#01100000b
    LCALL    div16_16     ;get the rpm using the formula: 60000/10* ms passed
    MOV    A,R3
    MOV    R1,A
    MOV    A,R2
    MOV    R0,A
    ;the following few blocks divide by 10, and get the individual digits that we're to output on our 7-segment displays
    ;for example, 1234 rpm:
    ;1234 div 10 = 123, mod = 4, least significant digit is 4
    ;123 div 10 = 12, mod = 3, second digit is 3
    ;12 div 10 = 1, mod = 2, third is 2, fourth is 1
    ;save each digit to it's designated ram address, which will be read and displayed in the main loop.
    ;note that the least significant digit is always zero, to make the display more readable (less fluctuations, easier code)
    ;and why the hell would you care if you're at 3501 or 3500 rmm anyway? :)
    MOV    R3,#0
    MOV    R2,#10
    LCALL    div16_16
    MOV    A,R0
    MOV    0018h,A
    MOV    A,R3
    MOV    R1,A
    MOV    A,R2
    MOV    R0,A
    MOV    R3,#0
    MOV    R2,#10
    LCALL    div16_16
    MOV    A,R0
    MOV    0019h,A
    MOV    A,R3
    MOV    R1,A
    MOV    A,R2
    MOV    R0,A
    MOV    R3,#0
    MOV    R2,#10
    LCALL    div16_16
    MOV    A,R0
    MOV    001Ah,A
    MOV    A,R3
    MOV    R1,A
    MOV    A,R2
    MOV    R0,A
    MOV    R3,#0
    MOV    R2,#10
    LCALL    div16_16
    MOV    A,R0
    MOV    001Bh,A
    CPL    P2.1 ;debug, safe to remove this line
    MOV    R0,#0            ;reset the overflow counter
    MOV    R1,#0
    POP    PSW
    POP    ACC
    MOV    TCON,#01010000b        ;re-start the timer
    RETI    ;return from interrupt
MASK:                           ; Subroutine that translates digits to 7seg
        INC     A
        MOVC    A,@A+PC
        RET
        DB    0C0H        ; Mask for 0
        DB      0F9H            ; Mask for 1
        DB      0A4H            ; Mask for 2
        DB      0B0H            ; Mask for 3
        DB      099H            ; Mask for 4
        DB      092H            ; Mask for 5
        DB      082H            ; Mask for 6
        DB      0F8H            ; Mask for 7
        DB      080H            ; Mask for 8
        DB      090H            ; Mask for 9
; **** the following routine is NOT mine, i borrowed it from www.8052.com since i couldn't have been bothered to write my own.
; **** it's very well documented, so you should have no problems with it if you need to know how it works anyway
; **** it divides R1R0 by R3R2 in 16 bit and stores the result in R3/R2 and the rest in R1/R0
div16_16:
  CLR C       ;Clear carry initially
  MOV R4,#00h ;Clear R4 working variable initially
  MOV R5,#00h ;CLear R5 working variable initially
  MOV B,#00h  ;Clear B since B will count the number of left-shifted bits
div1:
  INC B      ;Increment counter for each left shift
  MOV A,R2   ;Move the current divisor low byte into the accumulator
  RLC A      ;Shift low-byte left, rotate through carry to apply highest bit to high-byte
  MOV R2,A   ;Save the updated divisor low-byte
  MOV A,R3   ;Move the current divisor high byte into the accumulator
  RLC A      ;Shift high-byte left high, rotating in carry from low-byte
  MOV R3,A   ;Save the updated divisor high-byte
  JNC div1   ;Repeat until carry flag is set from high-byte
div2:        ;Shift right the divisor
  MOV A,R3   ;Move high-byte of divisor into accumulator
  RRC A      ;Rotate high-byte of divisor right and into carry
  MOV R3,A   ;Save updated value of high-byte of divisor
  MOV A,R2   ;Move low-byte of divisor into accumulator
  RRC A      ;Rotate low-byte of divisor right, with carry from high-byte
  MOV R2,A   ;Save updated value of low-byte of divisor
  CLR C      ;Clear carry, we don't need it anymore
  MOV 07h,R1 ;Make a safe copy of the dividend high-byte
  MOV 06h,R0 ;Make a safe copy of the dividend low-byte
  MOV A,R0   ;Move low-byte of dividend into accumulator
  SUBB A,R2  ;Dividend - shifted divisor = result bit (no factor, only 0 or 1)
  MOV R0,A   ;Save updated dividend
  MOV A,R1   ;Move high-byte of dividend into accumulator
  SUBB A,R3  ;Subtract high-byte of divisor (all together 16-bit substraction)
  MOV R1,A   ;Save updated high-byte back in high-byte of divisor
  JNC div3   ;If carry flag is NOT set, result is 1
  MOV R1,07h ;Otherwise result is 0, save copy of divisor to undo subtraction
  MOV R0,06h
div3:
  CPL C      ;Invert carry, so it can be directly copied into result
  MOV A,R4
  RLC A      ;Shift carry flag into temporary result
  MOV R4,A
  MOV A,R5
  RLC A
  MOV R5,A
  DJNZ B,div2 ;Now count backwards and repeat until "B" is zero
  MOV R3,05h  ;Move result to R3/R2
  MOV R2,04h  ;Move result to R3/R2
  RET
END
