Right, update - took the Stilo down to Abercorn and they tested the alternator. Fine under load and off - think it was 16-17 volts without load and 12-13 volts with load if I was reading the readout correctly and that was steady, not jumping all over the place.
Chap tested the battery and the charge was sitting well but the testing machine said the battery was essentially not in the best state so I've ordered a new one. Think the combo of running on a not well alternator and all those charges on a rather ancient battery charger's taken it's toll. So that's £60 I could've done without spending :/ Plus, there's still the slight alternator worn sound from cold I'm still getting. Spraying some silicone spray to relieve it, but still worried the current dodgy battery's doing the refurbed alternator some damage
Also, the rear brake situ is getting a bit worse I think. Reading up on it, I'm wondering if the handbrake's out of adjustment (which could account for the brake dust on both wheels) AND the OS calliper's sticking due to dodgy seals or a build up of gunk in said seals leading to the sticking. 100% sure the OS one's in a worse state than the other side, can tell from the faint groove on the disc that's appeared the last week or so though any kind of squealing and indeed heat build up seems to have been eliviated via some copper grease thankfully.
Thinking the brake issue needs sorted sooner than the hg - looking back at old pics, I think the hg has been in the same state for literally the best part of 2 years. I've noticed a slight leak from the rocker cover and in the pics, I noticed the same. Had thought originally it was just AR being shoddy and spilling oil on there
Anyway, refurbed calliper's £59 minus £15 if I send my old one back, which seems decent enough. Seals aren't apparently the easiest to replace on the Stilo's rears from what I've read. It is apparently pretty straightforward so long as the pistons are wound back properly and the not just g-clamped like some have done. Not that I'm 100% certain I could do this myself
Mildly tempted to get the discs and pads I was going to settle on and get it all done at the same time
