rolopolo
Established member
- Joined
- Jan 9, 2012
- Messages
- 837
- Points
- 308
Hiya,
For ones sins, and I apologise, I’m picking up my 5th new Ducato this week,
Fitting a Hope T-Bar to the rear, which will cause the reverse sensors to think I’m hitting a wall once reverse engaged,
Pretty sure I read either on MultiECUscan or here, that if you remove (disconnect) the sensor ecu, and run a proxy alignment, that will remove the sensors from memory and no warning triangle on dash,
I’m assuming the ECU will be located in a rear corner, or and is the audible “speaker”
Can anyone confirm the location please?
