Hi all I have a 2014 1.2 fiat Punto I recently had a refurbished gear box and new clutch fitted due to lay shaft bearing gone the car now drives fine all gears work as they should until I noticed parking sensors etc weren't working so I checked the usual culprits changed the reverse light switch after checking connector held the button in on the switch and all worked as it should engaged reverse gear and nothing then found that if I physically held the gear lever over to the right hand side it continued to work let go of the lever and it moved slightly and everything stops working has anyone faced this issue before or have any ideas of how to fix it or what's causing it to move enough to stop the switch doing its job thanks in advance
