Sheepy1209
- Joined
- Jan 5, 2012
- Messages
- 18
- Points
- 4
Hi, I know I'm probably asking a question already covered - I've done a search and think I know the answer but just want to confirm.
Basically - I've got a brand new 1.2 MyLife, which has the single-DIN Blaupunkt CD / Radio. I want to replace this with a single-DIN unit which has an AUX socket, plays MP3 CDs and, ideally, with a USB input. Loads around.
Before I buy I'm looking to confirm whether I'm right on the following:
1. The Panda has ISO connectors therefore will be a straight swap and won't need a harness adaptor
2. I'll need an ISO - DIN adaptor for the aerial
The thing I'm still not sure about is switched Live - does the Panda have one in its ISO connector, or will I need to rig one up from somewhere else? (This car has a 12V Socket on the floor, not sure if it's switched)
I recently replaced a 2006 Corsa's radio and had a similar issue - CANBUS controlled, had to run a wire round to the cigar lighter - but that one used a harness adaptor which included the extra lead.
