My 500C failed it’s MOT today because water had got into number plate housing causing bulb to fail. The garage tells me the corrosion is so bad that I will have to replace whole boot handle. List price is a steep £128 but there are some available on eBay for less. Please can anyone tell me whether 500C handle is same as on hatch and whether all pre-facelift cars have same handle.
The boot release had recently stopped working on both the handle and key fob and there is no sound from the switch. I imagine the corrosion in handle may be a contributory factor but have seen elsewhere in the forum that this may also be caused by wiring problems or the need to reset the roof. I had recently had to disconnect the battery so hoping it’s the latter rather than the dreaded wiring problem.
