Technical 2008 Fiat 500 door handle
Orkney Laika
Orkney
Good morning
I bought a new passenger door handle for my daughters Fiat 500 1.3 Multijet. Changing it across was no problem but I had a problem popping the connecting rod from the handle to the mechanism back in.
The rod has a groove at the top that should just pop in and clip in place but it refused to do so. I need to buy a replacement plastic single push clip but havent a clue where to start as I dont know the correct name for the part.
I would replace the bottom clip as well as it is brittle with age,
Can someone give me the correct names or the part numbers so I can get the door working properly.
Many thanks in advance.
Neil
