Technical removing head unit
I removed mine by sliding a feeler guage blade in to the the gap between the radio & the dash near the top of the radio.
I then slid the feeler guage blade to the bottom of the radio while pulling on the radio by the cassete slot.
That released that side of the radio, I then repeated the process on the other side & out it came.
Use a thickish feeler blade, as you slide it down it releases a catch it wasn't difficult, hope this helps.:)
I own 2 Fiats, is this a sign of madness??
Heres a link to a site which explains it with pictures, also if you have a Haynes manual it is explained in there, allthough they show it with 2 blades which isn't needed.
You must pull on the unit while sliding the feeler blade otherwise it wont work.
http://www.bravo-guide.co.uk/ice.htm#remove
Feel;er gauges will do the trick http://www.bravo-guide.co.uk/ice.htm#remove
That tells ya how to do it
a couple of quid at a dealer, they do a real nice job.
-=[uno 1.0ie RAAAWW!]=-
-=[fiat tech for what it's worth.]=-
I had the misfortune of the right side brace on the stereo becoming lodged into the dash and twisting, thus making it nearly imposible to get the stereo out, I still dont know how I got the bloody thing out. but all I know is, the right side metal brace is all twisted, bent and nearly distroyed. And all because I decided to stick the stereo back in after finding out I needed an ariel adaptor to stick my own unit in
Scorg
02 Stilo Dynamic 1.6
Sky Blue
01 Brava 80SX (and capable of 47mpg :D )
Ink Black
June 6th 1944
You will not be forgotten
hehe, ive seen one do that before.
there bugger too get out one its bent around.
Has anyone got any ideas on what i cud use to take out my headunit of my 2001 punto. Have just taken delivery of an Alpine 9831r but cant find the tools to take out the original headunit.. :(
