Technical Vents removal
bravopython111
Hi guys, can someone tell me how to remove the right side vent, I want to respray it, but it seems quite tight fitted, is there a way to remove it safely?-It's a left hand drive fiat bravo 2.0 20v non turbo one, thanks.
Yes, exactly. I have seen guides for center console, but can't figure out that specific part.
You have to get it from underneath.
You have to take the glove box out then there are two or three fixings. I have seen alen key type and pan head type screws on different cars.
Unfortunatly the manual only says remove the fixing bolts, I believe from memory there are two or possibly three bolts holding it on. Once you take them out pull the vent out towards you.
