Technical Removing door inner panel
Orpington, Kent UK
I am trying to remove the door inner panel from my donor door. I’ve removed the window electrics, undone all the quarter turn white fixings all the way round but something g is still holding it firmly in place.
I cannot find any other fixings. Help! Picture attached.yView attachment 194991
Hello! Wondering if you can help. I have a similar lining with white quarter-turn locking washers on my 2016 Fiat 500X. However, before I attempt to pull that lining back/off to access the failed exterior door handle, I need to disconnect the wiring to the driver armrest door/window control panel. There are two electrical connectors that refuse to come apart. One has a release tab; the other does not appear to have any release feature. Any suggestions? Thank you.
I haven’t uploaded video yet but just thought I would let you know, bodyshop cost me £400 to paint two blue doors to black, paint a new front wing and fit, rehang the doors and put it all back together.
You ever upload that video? I’m having same problem. Can’t figure out how to get internal plastic liner off. Any help would be appreciated!
Same here. I’m trying to replace the exterior door handle as well. I was able to get the door handle itself off by the tiny screw on the door jamb but something in the door is keeping it from seating correctly. This membrane is in my way. Anyone with answers please help!
Was trying to fix a friends driver side door handle on their 500x. The inner panel seems to have a screw that’s facing inward that I can’t get access to. It’s located near the white qrt turn anchor, second one in from the top right-hand side. I believe that it may be the fastener that’s keeping the panel from being removed. Idk wth it’s fastened to. Maybe the window regulator track? Any how, were you able to figure this out?
hi the window glass has to be removed from the window regulator 2 bolts
