Technical  Remove front center seat
bigwaver
Hello.
I have read several similar posts before writing but also because of my English I have no clear ideas.
In a multiple of 2002 by removing the middle seats used to get a cargo uniform and more than 2.4 meters long. I now have just purchased a Multipla emotion 08 and for transporting the windsurfing want to remove the central front seat in order to obtain the same result
The pyrotechnic of the safety belt is attacked to the seat?
It 'attacked with just 4 bolts?
Unscrewing the 4 bolts off?
Help me step by step to understand the procedure? possible without removing the two front outboard seats.
Thanks in advance!:worship:
I believe you have to remove the two front outer seats to get access to the securing bolts for the middle seat!!!! The pyrotechnic is attached but should have a connector which helps, however disconnect the battery before starting the job and make sure you have the radio code!!!
Thanks for the answer.
Yesterday, looking closely, I saw that you are the sides of the seats in plastic shrouds for air, behind which there are the nuts that hold the seat to the bottom (touch them with your fingers). Each is attached by a screw conveyor to the floor and with a hexagonal screw and a nut on the seat. After removal of the conveyor can see the nuts that hold the seat. Calmly, working under the side seats, you can unscrew with a wrench 16. If the fireworks display is attached only to the seat you're done. Without disassembly of the side seats
Or at least that's the theory.
Someone confirm this procedure?
Excuse me and google translator.......
Sorry but do you have to take middle seat off completely to carry your surf board?
Would it not fit if you just recline back of seat forward and rest the surfboard diagonally on top of it jamming it between the other 2 seats?? I dont do surf so i dont know how big a surfboard his so forgive me if this solution wont work
Hello.
My windsurfing are 2.46 meters long. Keeping the configuration with 6 seats, removing the right rear seat, reclining the front right and closing the center, I managed to get inside resting them, two boards, three sails, etc.. but so there are only 2 seats including the driver, my wife can not sit next to me and little space in the trunk, also would not want to ruin the seats or dashboard. In a multiple of 2002 from a friend, where the front seat was on the skids, after taking off 2 stations, exploiting the hollow below the gearbox in the tunnel that was created could load three tables, four sails, etc.. 4 seats remained free, double the boot space, The seat beside the driver was free and everything was neat and stuck between the seats.
Hello Boys.
Eventually I managed to remove the front center seat.
All my reasoning as before, it ended when I discovered that the bolts are 6 instead of 4.
Anyway with the help of my girlfriend I did not need to drop the connectors of the airbag.
I did the following:
I first dropped the bolts without removing the seat side airbags, I tilted the seat forward first and then back to unscrew the bolts and remove the air conveyors (faendo attention to the airbag connectors). it was all just gave up, I removed the middle seat then tightened the bolts of the side seats.
Now I have the "multipla" with the load floor that I wanted.
I put air flow vents to the attacking side seats with a black plastic strip and inserting between them a thick rubber. The center to cover the bolts of the front seat center I put a mat of the same color of the upholstery.
Thanks for your help.
If you need put some pictures.
Bye!
Mo sta m'a senti !It's easy to remove the center front seat, I've taken mine out several times, all you need to do is take the other two out for access to the bolts, I never bother disconnecting the battery, I don't see what the need for that is.
If you want to take the seat out often it would be worth changing the bolts for captive studs on the seat and you can remove nuts and washers from underneath, or you may be able to just take out the normal passenger seat and get your stuff in like that. Recentamente ho guidato fino ad Imola per carricare le moto d'epoca la mia multipla é come un furgone di lusso ! Forza Napoli !
