Hi, I have a Fiat 500 L and the off-side rear light cluster has a problem. The position light and the brake light are working fine but the LED lights around the outer rim of the light have failed. The LED lights on the near side are fine so the absence of the lights on one side is obvious. I had a couple of queries and would be very grateful for advice.
1) can the LED lights be repaired or do I need to replace the cluster?
2) I live in the UK - is the absence of the LED lights on one side although the main position light and brake light are working normally a MoT failure?
Any help and ideas most welcome
