- Joined
- Jan 20, 2013
- Messages
- 6,151
- Points
- 1,228
got a punto 95 1.1 that was not driven for about a year
failed mot test cuz of right rear foot brake (cylinder was seized) and left handbrake was on the limit, but still working, also left rear foot brake was on the limit- later discovered that cylinder was only pushing out on one side
so i changed both rear brakes cylinders and brake pipes, bleed both rear brakes, adjusted both rear pads so the drum would fit on tightly but still move freely, removed the drum lip which was rly small, applied copper grease on the back, used brake cleaner on pads and drum, and drove it there again
now it showed that left rear foot brake and handbrake wasnt working how it should despite new cylinder, around 40-50% difference in braking between left and right rear wheel
dunno what seems to be da problem, perhaps a handbrake cable?
picture below is the left rear wheel that is making problems
