Technical rear brakes problem
well brakes finally fixed, there was no need to buy new pads and cables as i just didnt know how to adjust shoes properly
took it to a buddy and he showed a little trick that everyone forgot to mention, you are supposed to adjust shoes after drum is already on through that little hole on drum
after 1 year mystery is finally solved
I thought that was for use with manual adjuster shoes. Can the the automatic adjuster be adjusted through that hole too. Would like to know if this is the case so I can adjust mine so that the braking will be fully balanced, i.e. 3 clicks both 100%.
it can be adjusted, get a flashlight and you just need to push shoes more apart after drum is back on
adjust them 1 click at a time
you are supposed to stick screwdriver where arrows are pointing and push apart till you hear a click
shoes in one picture are already pushed all the way
