Many thanks for this! Went to Fiat dealer and they have ordered me some for £20 posted. Bit more expensive but should be ok.
They just tapped out so hopefully still work when I reconnect. Incidentally, the stub axle, I have removed the 4 nuts but it still wont remove from the axle, is there something I have missed?As you need to move the whole hub over I left the abs sensors in place rather than break one?
It will outlast the car so possibly no I didn't do ours, or not until fitted you don't want it all slipperyThanks all! This thread is great! Should I waxoyl the new axle when fitted? Still waiting for bolts to be delivered from Fiat, so at a standstill at the moment![]()
That or a spray over with a can of stone-chip, paint to keep water and road debris away!It will outlast the car so possibly no I didn't do ours, or not until fitted you don't want it all slippery
IM do an affordable replacement for the 1.4 500 axle (just select the disc brake option), so probably not worth the effort of trying to salvage a marginal one.I've a 2008 1.4 scrubbed up but worn (corroded) axle.
Bit thick maybeIM do an affordable replacement for the 1.4 500 axle, so probably not worth the effort of trying to salvage a marginal one.
It's the 1.4 Panda that leaves you in the hard place.
Their advert appears at tge top of the main forum page as it scrolls throughBit thick maybebut who's IM
Now you've really lost meTheir advert appears at tge top of the main forum page as it scrolls through
Start on the homepage! underneath the words FIAT FORUM is a blue box through which adverts scroll the axle supplier Im appears in the sequence! have to wait a while when it comes up click on it!!.Now you've really lost me![]()
Yippee! Thanks for reducing to my level. Others assumed too much mental capacityStart on the homepage! underneath the words FIAT FORUM is a blue box through which adverts scroll the axle supplier Im appears in the sequence! have to wait a while when it comes up click on it!!.
all good!Yippee! Thanks for reducing to my level. Others assumed too much mental capacity.
I tried to follow John202020 and arrived at IM Solicitors.
Trouble is when you fit a nice new part it shows up the rest dont it!"It’s finally fitted! Yippee! However, bit of modification is needed on the offside bottom shock absorber mount, they don’t line up but only out by a little, so file a bit and it fits! Great axle from IM! I am so pleased! Just waiting for my springs to arrive!
