Technical Rear Axle Replacement ?
Exciting delivery this morning!
Bolts check the size but Ebay your friend
Maybe this just a guess
Many thanks for this! Went to Fiat dealer and they have ordered me some for £20 posted. Bit more expensive but should be ok.
As you need to move the whole hub over I left the abs sensors in place rather than break one?
They just tapped out so hopefully still work when I reconnect. Incidentally, the stub axle, I have removed the 4 nuts but it still wont remove from the axle, is there something I have missed?
Thanks all! This thread is great! Should I waxoyl the new axle when fitted? Still waiting for bolts to be delivered from Fiat, so at a standstill at the moment 😔
Start on the homepage! underneath the words FIAT FORUM is a blue box through which adverts scroll the axle supplier Im appears in the sequence! have to wait a while when it comes up click on it!!.
Yippee! Thanks for reducing to my level. Others assumed too much mental capacity 🤡.
I tried to follow John202020 and arrived at IM Solicitors 😩.
It’s finally fitted! Yippee! However, bit of modification is needed on the offside bottom shock absorber mount, they don’t line up but only out by a little, so file a bit and it fits! Great axle from IM! I am so pleased! Just waiting for my springs to arrive!
Trouble is when you fit a nice new part it shows up the rest dont it!":rolleyes:🤣
